(2021-07-17, 23:37)josavvyy Wrote: [ -> ] (2021-07-15, 14:00)beuter Wrote: [ -> ] (2021-07-14, 00:04)adultmm Wrote: [ -> ]Hi Guys,
I hope, I've fixed the security error. Could you try it?
You can download it here:
https://github.com/adultmm/AdultMediaMan...7.6.3-beta
@beuter
@josavvyy
Hi, now i get a 418
I no longer get the google error. I scraped 100 videos and all was well. It's much faster as well.
Thank you @
josavvyy, I've released the new version.
(2021-06-29, 00:44)adultmm Wrote: [ -> ] (2021-06-28, 21:42)Johnson_Stgt Wrote: [ -> ]That would be a great thing from my point of view!
(2021-06-28, 17:02)adultmm Wrote: [ -> ]
The "Ask (require input if no exact match)" method selects the first match if the title of the movie - after some transformation - exactly matches. It means 100 scores. You can check the calculated score in the search result window. What is the score there for the movie? What is your exact filename?
The "Automatic (Force best match)" method requires 99 scores.
The score is 100 at adultdvdempire and 98 at Dorcel Vision (here the first result is not the correct one) and no result is found at TMDB. The filename is "Big Natural Tits 3.iso", but I have selected the "Movies are in seperate folders" and "Use folder name for initial listing" option as well as "Get year from folder name". The folder name is "Big Natural Tits 3 (2001)".
There's a bug with runtime scraping of movies. It causes the problem. I'll fix it in the next version. Thanks for your help.
Johnson_Stgt This bug has been fixed in v0.7.7.
Hi @
Zertos,
(2021-07-14, 21:13)Zertos Wrote: [ -> ]Thanks for this scraper!
I have a few questions:- Is the module scraper compatible with the newest ember version 1.10? I copied the modules folder to the ember modules but I can't find the scraper under the modules tab of the settings.
No, it isn't. You can use v1.9.x version only, but EMM is a portable app, so you can easily use different versions for your movies and adult contents.
(2021-07-14, 21:13)Zertos Wrote: [ -> ] - Can you add the site anidb.net to scrape hentais? They are tv shows there.
I put it on my to-do list. (It's a bigger task, AdultScraper hasn't support TV series yet.)
(2021-07-14, 21:13)Zertos Wrote: [ -> ]- Could you add Sexart and Vivthomas to your scraper?
I put them on my to-do list.
Hi @
slappy,
(2021-07-07, 13:52)slappy Wrote: [ -> ]Thanks for this great scraper !
Thank you!
(2021-07-07, 13:52)slappy Wrote: [ -> ]I dont see support for analvids.com (www.legalporno.com).
Can someone confirm please.
It's on my to-do list, but it's not supported yet.
(2021-07-07, 13:52)slappy Wrote: [ -> ]Also
Is there a way we can see images for poster and fanart from the huge database of vipergirls.to or planetsuzy web ?
It's not too easy to found and parse information from the free-text of forums, and the result is doubtful, so it's not a priority in my plans.
(2021-07-19, 18:47)adultmm Wrote: [ -> ] (2021-07-15, 14:00)beuter Wrote: [ -> ] (2021-07-14, 00:04)adultmm Wrote: [ -> ]Hi Guys,
@beuter
@josavvyy
Hi, now i get a 418
This error comes from DDG Searcher. I cannot reproduce it with my movies but I implemented a rate limiter there. We'll see, but I released the new version (v0.7.7) because it has a much better result.
Thank you for all your hard work!
I tried the new version, got no errors whatsoever
(2021-07-20, 13:11)adultmm Wrote: [ -> ] (2021-07-20, 11:29)beuter Wrote: [ -> ] (2021-07-19, 18:47)adultmm Wrote: [ -> ]Hi,
Glad to hear it.
Thanks for this! I am having a problem with nubiles.net. Nubiles Porn works well but I can't get a match with any nubiles.net videos.
(2021-07-21, 03:15)josavvyy Wrote: [ -> ] (2021-07-20, 13:11)adultmm Wrote: [ -> ] (2021-07-20, 11:29)beuter Wrote: [ -> ]Thank you for all your hard work!
Glad to hear it.
Yes, yes, nubiles.net is not supported, because neither Google find the videos:
https://www.google.com/search?q=Breathta...ubiles.net
Maybe, I'll find a solution later...
With the new release, I'm getting 429 errors after about 10 scrapes with most scrapers (RealityKings and XEmpire for example)
Any way to add Bang! to the list of scrapers?
Thanks for your effort!
(2021-07-24, 12:50)josavvyy Wrote: [ -> ]With the new release, I'm getting 429 errors after about 10 scrapes with most scrapers (RealityKings and XEmpire for example)
When I switched back to the previous beta, I was able to process many more videos wit this error.
what a gem of software , maybe you can integrate with “theporndb"
https://metadataapi.net/ for more Scraper sources.
Thanks for this , keep update for so wonderful software !!
Hi Guys,
Sorry for the late answer, but I was on my holiday.
As I can see, DDG searcher sometimes detects too many requests despite the rate limiter. My next idea is to use
Tor proxy so we can switch to a new IP address in these situations. It's not too easy to implement, I have to integrate an external software, but I'm on it.
My plans for the next period:
- stabilize the search capability
- fix some smaller bugs in the existing scrapers
- one of my Users sent me money for a special Scraper (thanks for it!), so I'll implement it as we've discussed (it'll be available for everybody)
- finish some semi-finished scrapers
- check the possibility to integrate
- check the work needed to upgrade EMM 1.11.x
Keep in touch here or on
GitHub.
(2021-07-26, 12:59)josavvyy Wrote: [ -> ] (2021-07-24, 12:50)josavvyy Wrote: [ -> ]With the new release, I'm getting 429 errors after about 10 scrapes with most scrapers (RealityKings and XEmpire for example)
Hi @
josavvyy,
429?
It's really strange. 429 error is sent by Google, but we use DDG for search, and Google is only a fallback if there isn't any (good) result.
Could you send me the log with the 429 errors?
(2021-08-07, 04:00)plsharevme Wrote: [ -> ]what a gem of software , maybe you can integrate with “theporndb" https://metadataapi.net/ for more Scraper sources.
plsharevme, thank you for the kind words. I have some other tasks in my to-do list - see my earlier post - but I'll definitely check the possibility to integrate metadataapi. Unfortunately, their API descriptor is not available
https://metadataapi.net/docs.openapi, but we'll see.
(2021-08-10, 17:28)adultmm Wrote: [ -> ] (2021-08-07, 04:00)plsharevme Wrote: [ -> ]what a gem of software , maybe you can integrate with “theporndb" https://metadataapi.net/ for more Scraper sources.
@plsharevme, thank you for the kind words. I have some other tasks in my to-do list - see my earlier post - but I'll definitely check the possibility to integrate metadataapi. Unfortunately, their API descriptor is not available https://metadataapi.net/docs.openapi, but we'll see.
Your todo list is so great !! keep it up.
