Full Version: RC1 - Can't move node in skin configurator
I created some nodes of my own for the movies Main Menu item. But I can't change the order. When I want to do this. I get this screen:
Imagehttps://drive.google.com/file/d/1t2GGVVr...sp=sharing
Remote doesn't work anymore (I hear GUI sounds, but can't see anything move and change). I only can click cancel ('annuleren' in dutch) with a mouse.
Log file:
https://paste.kodi.tv/fuzolexahi.kodi
Thanks for looking into this
Don't use the node editor at all, but it seems like the problem starts here:
ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting C%3A%5CUsers%5CNUCHOLLYWOOD%5CAppData%5CRoaming%5CKodi%5Cuserdata%5Clibrary%5Cvideo%5Cmovies
which suggests to me something went wrong with your userdata library folders.  You might try copying over (to a backup location) whatever folders you currently have in the userdata "library" folder tree then run library node editor and try setting video to "default" and start over from there.  You could try to selectively copy over files from your backup but that might be more work than just starting over.
scott s.
Thanks for the response.
See my other post: https://forum.kodi.tv/showthread.php?tid...pid3011869
Started all over again, but still no luck. Can't change the node order.
Is it possible to move this to the following forum:
> Support > Skins Support > Estuary
Maybe someone there will have a solution to this.
If it's an issue with the Node Editor then you should post here https://forum.kodi.tv/showthread.php?tid=224512
