So far I've used the normal (Pi to TV) interface and the remote control-keyboard to change titles. This is slow and painful. Can that be done from the web interface where I have a real keyboard and also cut&paste functionality. Thanks...RDK
(2021-02-11, 18:41)rdk45 Wrote: [ -> ]So far I've used the normal (Pi to TV) interface and the remote control-keyboard to change titles. This is slow and painful. Can that be done from the web interface where I have a real keyboard and also cut&paste functionality. Thanks...RDK
Yes, u can change the title plus other things too via Web interface
Geee, thanks. What I really need is the "How to do it" info or a good reference....RDK
(2021-02-11, 18:56)rdk45 Wrote: [ -> ]Geee, thanks. What I really need is the "How to do it" info or a good reference....RDK
Do you have Chorus2 webinterface enabled?
If yes, go to the webinterface eg kodi ipaddress:port
The select a movie your want to edit, so it brings up the movie detail page up. Click on the button that says more which has 3 dots next to it. It will then bring up a menu , at the bottom of the menu it will say edit, click on that and it will bring up the edit page, for the movie.
If u need more info let me know
I have the default web interface which came with the OSMC install. Not sure if it is the Chorus2. How do I determine this?...RDK
I tried your suggestion and it works.....Many thanks....RDK
