2021-02-12, 10:32
Hello All,
I created my first plugin for my media network. I'm able to pull down the json file and then shows accordingly. I'm working on cleaning up everything to make it look nice. The shows play as they should. However, what I am noticing is with the ace 2 skin when I load up the shows it is looking for seasons and episodes. Is this I'm guessing something that I need to set myself and if so is that using the setInfo? I'm looking to try that but thought I'd check if it should auto generate first. I've attached my plugin here on github. However when I load a show it goes to my season list. However the skin still thinks it is showing show names and is again showing seasons and episodes with nothing in it. I thought I had set the content type correctly but my guess is not. I was looking at https://codedocs.xyz/AlwinEsch/kodi/grou...fc1e2318d6 for reference but if this is incorrect please let me know. I'm using Kodi 18 version.
GitHub: https://github.com/SimplySynced/plugin.v...cape.media
Thank you for taking a quick peek!
