2021-02-15, 02:43
Hello,
I just downloaded Kodi a few hours ago, so new user. Windows 10 20h2
Processor Intel® Core i5-8600K CPU @ 3.60GHz 3.60 GHz
Installed RAM 64.0 GB 2666
System type 64-bit operating system, x64-based processor
windows defender on but not scanning
I installed no issues
Source 6TB in a usb dock 3.1 G2 connected to usb 10Gbps io port
I added source file TV shows, Movie and scanned them and populated correctly but...
Every time I click my mouse there was 20+ seconds lag. Yes the imports were complete. So I moved the files to an internal ssd cleared the libraries, then added the new source locations as before. TV shows populated as before but the movies only show 10 recently add on the home page.
If I click movies nothing is there. Just the 10 in recently add. I cleared the movie library and removed the source, then re-added to try a new scan. No change.
How do I get the movies to populate? The scan did run and finished It was still running in the background for about 5 minutes (watching the hdd light) and seeing cpu usage never got above 10%. I have not tried to uninstall it and reinstall yet.
