2022-01-06, 13:21
2022-01-06, 16:13
(2022-01-06, 11:49)Karellen Wrote: [ -> ]But it is not used?(2022-01-06, 10:40)xp_eric Wrote: [ -> ]Maybe I misunderstood...Actually I don't think you did. You needed to remove the requirement for that addon from addon.xml file in the skin. If you don't remove it, the skin will fail to install. I have commented out that requirement, so the skin will install.
That is probably where you got stuck.
2022-01-06, 19:33
(2022-01-06, 13:21)hurricane51 Wrote: [ -> ]but it appears I need to create an account to download the file. Is that correct?No. Click on the Free Download button.
2022-01-06, 19:54
I did, and stepped through multiple pages to get the download, and then reached a page requiring me to set up a free account. I'll try it again.
2022-01-06, 21:02
(2022-01-06, 19:54)hurricane51 Wrote: [ -> ]I did, and stepped through multiple pages to get the download, and then reached a page requiring me to set up a free account. I'll try it again.I see the site has changed a bit since I last used.
After you select Free Download, from the pop us select Slow Speed then ignore all the stuff about free account. The download should then start in a few seconds.
I'll try to find another site that doesn't bombard you with advertising.
2022-01-06, 23:12
(2022-01-06, 09:45)Karellen Wrote: [ -> ]Here is the zip file for installing Transparency! on Matrix v19... https://ufile.io/a6rf2yu8Thanks Karellen, you're the best!
Download and install via zip from within Kodi.
While I still use Kodi DSPlayer (stuck at 17.6), missing Transparency was one of the things holding me back Although I must admit that Amber can be good once setup correctly. But the fanart view of Transparency! remains unparalleled.
For what it's worth, I used your link, clicked twice (free download and then slow download) and I did not have any problem downloading it.
2022-01-07, 05:14
I did click the download link, but nothing happened, so I thought I had to register. Turns out the download was failing for some unknown reason. I rebooted and everything worked. Thanks.
2022-01-08, 04:45
Thank you Karellen for sharing!
2022-01-10, 21:27
I am getting a failed due to an invalid structure message when i try to install the above zip.
2022-01-10, 22:06
(2022-01-10, 21:27)hostile17 Wrote: [ -> ]I am getting a failed due to an invalid structure message when i try to install the above zip.Exit Kodi.
Close any file managers, like Windows Explorer, that are open.
Start Kodi and try again.
2022-01-11, 00:02
(2022-01-10, 22:06)Karellen Wrote: [ -> ]I am using a Nvidia Shield and as far as i know there are no file managers open.(2022-01-10, 21:27)hostile17 Wrote: [ -> ]I am getting a failed due to an invalid structure message when i try to install the above zip.Exit Kodi.
2022-01-11, 00:09
2022-01-11, 07:32
Followed your suggestions but still no luck.I will have to look up how to get the debug log.
2022-01-11, 07:42
Also just tried on a completely new installed fork with the same result.
2022-01-11, 08:04
