2021-03-03, 21:57
(2021-02-28, 00:28)RyFeR Wrote: [ -> ]@RyFeR , you are correct; I just fixed this. The changes are already on GitHub.(2021-02-27, 01:17)RyFeR Wrote: [ -> ]Hi Bart,(2021-02-27, 00:01)bsoriano Wrote: [ -> ]@RyFeR , could you please try the latest from GitHub? I made some changes to the seek bar that should fix this issue. Please let me know if it is indeed fixed. Thanks.Hi Bart,
Regards,
Bart
Confirmed the seekbar for the next episode is now again showing correctly after your fix.
You're the best!
Last thing about the seekbar I hope... Just noticed that when pressing "Info" the information about the current movie / episode is displayed but the seekbar is not. In the previous builds (09-02-2021 and before) the seekbar was displayed together with the info. Can you restore this behavior?
Regards,
Bart
