Full Version: Font size in File Manager
Although throughout the skin the font setting of Small / Regular / Large has a noticeable effect, the font size in the File Manager seems unaffected and is rather small.
Would it be possible to make that bigger / use an option (separate / linked to the overall skin font setting) to select the font size in the File Manager?
(2021-02-20, 16:14)RyFeR Wrote: [ -> ]Although throughout the skin the font setting of Small / Regular / Large has a noticeable effect, the font size in the File Manager seems unaffected and is rather small.
@RyFeR , thanks for pointing this out.  I had not noticed since I do not use the file manager at all.  I will look into this.
Regards,
Bart
@RyFeR , I have made the changes so that File Manager uses the font sizes that the rest of the skin uses.  The changes are on GitHub already.
Please let me know if you are able to update from GitHub.  If not, please wait a couple of days and I will upload a new version to the Amber repos.  Thanks.
Regards,
Bart
(2021-02-23, 17:50)bsoriano Wrote: [ -> ]@RyFeR , I have made the changes so that File Manager uses the font sizes that the rest of the skin uses.  The changes are on GitHub already.
Regards,
Bart
Hi Bart,
As always your fixes are spot on, confirmed that the font size in the file manager now scales with the Small/Regular/Large font setting of the skin.
Thx for the quick update!
(2021-02-23, 23:02)RyFeR Wrote: [ -> ]
Regards,
Bart
Hi Bart,
@RyFeR , you are welcome.  Thanks for confirming it is working as expected.
Regards,
Bart
