Cue sheet and Flac appears to work fine on my Vodafone TV Box Kodi (Android) but the behaviour on Windows Kodi Matrix Stable is strange. It never has worked on the Windows versions of Kodi. Only the first INDEX item is found. Very strange.
The code is common to all platforms AKAIK, so that sounds very odd. Can you share an example cuesheet, and are they embedded in the FLAC or separeate.
I am going crazy. If I rename the .flac file by simply adding a space to the filename (before the .flac) - all works fine. Is it to do with long filenames in Windows ? and special characters?
So if I rename 'Vivaldi Four seasons.flac' to 'Vivaldi Four seasons .flac' all works fine. The cue sheet finds all the index files.
That sounds very unlikely after all adding a space makes the filename longer, please post an example cuesheet.
Here is example cue sheet. Only the first Track is detected. But if I rename the flac file in Windows to ADD a 'space' to the filename so it ends in 'Anner Bylsma .flac' , all 12 tracks are detected.
PERFORMER "Robert Levin, Vera Beths, Anner Bylsma"
TITLE "VIVARTE - 60 CD Collection (CD 32) Haydn - The Last 4 Piano Trios"
FILE "VIVARTE - 60 CD Collection (CD 32) Haydn - The Last 4 Piano Trios - Robert Levin, Vera Beths, Anner Bylsma.flac" WAVE
TRACK 01 AUDIO
TITLE "Piano Trio No. 43 in C major, Hob. XV:27 - I. Allegro"
REM COMPOSER "Franz Joseph Haydn"
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "Piano Trio No. 43 in C major, Hob. XV:27 - II. Andante"
INDEX 01 08:13:50
TRACK 03 AUDIO
TITLE "Piano Trio No. 43 in C major, Hob. XV:27 - III. Finale. Presto"
INDEX 01 13:16:62
TRACK 04 AUDIO
TITLE "Piano Trio No. 44 in E major, Hob. XV:28 - 1. Allegro moderato"
INDEX 00 20:03:72
INDEX 01 20:11:50
TRACK 05 AUDIO
TITLE "Piano Trio No. 44 in E major, Hob. XV:28 - II. Allegretto"
INDEX 01 28:08:50
TRACK 06 AUDIO
TITLE "Piano Trio No. 44 in E major, Hob. XV:28 - III. Finale. Allegro"
INDEX 01 31:37:50
TRACK 07 AUDIO
TITLE "Piano Trio No. 45 in E-flat major, Hob. XV:29 - I. Poco Allegretto"
INDEX 00 36:30:02
INDEX 01 36:37:50
TRACK 08 AUDIO
TITLE "Piano Trio No. 45 in E-flat major, Hob. XV:29 - II. Andantino ed innocentemente"
INDEX 01 44:30:50
TRACK 09 AUDIO
TITLE "Piano Trio No. 45 in E-flat major, Hob. XV:29 - III. Finale. Allemande. Presto assai"
INDEX 01 47:33:37
TRACK 10 AUDIO
TITLE "Piano Trio No. 42 in E-flat major, Hob. XV:30 - I. Allegro moderato"
INDEX 00 53:04:55
INDEX 01 53:12:50
TRACK 11 AUDIO
TITLE "Piano Trio No. 42 in E-flat major, Hob. XV:30 - II. Andante con moto"
INDEX 01 66:08:50
TRACK 12 AUDIO
TITLE "Piano Trio No. 42 in E-flat major, Hob. XV:30 - III. Presto"
INDEX 01 70:56:67
Out of frustration, I uninstalled Kodi and re-installed (19.0 Matrix) and rescanned all the albums - and all appears to be OK. What a relief. New albums get added correctly. Maybe there was a database corruption. Many thanks to all.
(2021-02-22, 12:13)DaveBlake Wrote: [ -> ]Thread marked solved.
Hello,
I have similar problem. The above solution seems odd and doesn't work for me.
Yesterday my Android box updated Kodi to Matrix and requested to rescan my music library.
After that ALL my music discs that are in the single FLAC + external cue sheet format show only the first song of the album.
Everything was OK before upgrade. I tried the trick described above, rescanned the library multiple times without success.
Another issue which might or might not be related.
I removed ALBUM tag from couple of songs that I want to appear in Singles and then performed Clean and Update library, but they still appear in Albums but not in Singles.
Oh dear, sorry to hear that this has appeared on Android Kodi. I thought maybe it was confined to Windows versions only. So have you uninstalled Kodi Matrix , rebooted the Android box and re-installed and rescanned?
(2021-02-24, 05:54)sparklingpersonality Wrote: [ -> ]So have you uninstalled Kodi Matrix , rebooted the Android box and re-installed and rescanned?
No, I thought maybe the issue could be solved without reinstall, but if there is no other solution I will do it.
After Kodi reinstall the problem is solved. Don't think it is a real solution... It means that something is broken in v18 -> v19 upgrade.
Drat, I'm having the same problem on Android TV. Will try reinstalling.
For anyone looking for the solution, probably removing and adding again music media sources should solve the issue. Seen this recommendation after doing reinstall...
