Hello everyone,
When I tried to migrate from v18.9 to 19, I got the error "Thread 3820 (process 3288), Thread 3940 (process 3936)"
And after that, Kodi 19 had closed itself. (and messed up something in my configuration folder)
When I back to v18.9, with the backup of my configuration folder, everything worked as before, normal.
What could this error be? (it only happened with kodi v19)
Don't migrate and call yourself lucky. 19 doesn't work the the vast majority of plugins and builds so I now have a base build of kodi.
(2021-02-23, 01:26)HRPuffnstuff Wrote: [ -> ]Don't migrate and call yourself lucky. 19 doesn't work the the vast majority of plugins and builds so I now have a base build of kodi.
Don't you mean the addon and builds don't work on kodi 19, the way your saying it, sounds like kodi is the problem when it not, nothing wrong with kodi 19 .
And as our
piracy policy (wiki) explicitly states we do not support builds nor any plugin on the
banned addons (wiki) list, the fact that they don't work and will hopefully die off and stop tarnishing the good name of Kodi is a plus for us.
You did not enable Debug Mode, so there is not enough info, but I think your hardware is too old.
Provide a proper
Debug Log and I might be able to confirm.
(2021-10-12, 21:17)Karellen Wrote: [ -> ]You did not enable Debug Mode, so there is not enough info, but I think your hardware is too old.
Provide a proper Debug Log and I might be able to confirm.
OK, by the way, with the 19.2 version, I don't have problems to use IPTV add-ons, to reproduce files by the player, but with youtube add-on I always get the error "Thread 4072 (process 4068) # 0"
(Remembering that with the v18.9 I don't have any kind of problem, runs smoothly)
I will post a debug log as soon as possible.
Thank you so much.
(2021-10-15, 12:43)MarlonRiosForsgren Wrote: [ -> ] (2021-10-12, 21:17)Karellen Wrote: [ -> ]You did not enable Debug Mode, so there is not enough info, but I think your hardware is too old.
Thank you so much.
Logs can be found at:
https://paste.kodi.tv/veqetivasa.kodi
Is it needed to attach the DMP file?
(2021-10-15, 12:54)MarlonRiosForsgren Wrote: [ -> ] (2021-10-15, 12:43)MarlonRiosForsgren Wrote: [ -> ] (2021-10-12, 21:17)Karellen Wrote: [ -> ]You did not enable Debug Mode, so there is not enough info, but I think your hardware is too old.
Thank you so much.
Logs can be found at: https://paste.kodi.tv/veqetivasa.kodi
A proper log provided. Hope that could help:
https://paste.kodi.tv/uxexodedez.kodi
Thank you in beforehand.
MarlonRiosForsgren
As I said earlier, I think your hardware is too hold. A quick google shows your graphics component was released 1st qtr 2007 and does not satisfy minimum requirements for Kodi...
https://kodi.wiki/view/Windows
xml:
ERROR <general>: CVideoPlayerVideo::OutputPicture - failed to configure renderer
If v18.9 works for you, then best you stick with it or get some newer hardware.
(2021-10-16, 01:18)Karellen Wrote: [ -> ]@MarlonRiosForsgren
As I said earlier, I think your hardware is too hold. A quick google shows your graphics component was released 1st qtr 2007 and does not satisfy minimum requirements for Kodi... https://kodi.wiki/view/Windows
xml:
Well, on PVR IPTV simple I am able to watch content in 1080p, as to play local videos... By the way, thank you for your time.
