Full Version: No vu+ client addon on Matrix official repository?
Hi, my intel nuc kodi auto updated from the windows store to Matrix and i lost the enigma2 client (compatibility issues).
There is no PVR addons at all from the official repository inside my kodi 19.
Ive found that now this addon is renamed to prv.vuplus. But cant find it on the ADDons to download.
Can someone help me?
Should i try to download the .zip and install manually? Do someone got a link to try?
ty
they exist on our mirrors and should be available to install from within kodi -> addons -> install from repository
https://mirrors.kodi.tv/addons/matrix/pv...ws-x86_64/
(2021-02-26, 14:53)wsnipex Wrote: [ -> ]they exist on our mirrors and should be available to install from within kodi -> addons -> install from repository
For some reason there is only 4 folders on kodi addon repository
Game aadons
Information providers
Look and feel
Web interface
I don't know why
Las time i got issues was on some updates from 18 which went from Windows store legacy compatible to UWP
idk,
How can i check if i got the UWP version or the good old one?
Edit: ty for the link, installed .zip and it updated my old enigma 2 keeping settings and now everything is working on 19. Smooth update.
But imho there is some bug preventing browse all matrix addon repository.
Ty guys, keep the great work up
Just here to say that right now kodi official repository is working as intended for me, showing all add-ons now including the vu+ one, everything auto updating.
Ty
Hello,
could you be so kind and help me where I can find a working addon for my X96max+ (Android) ?
I tried to download from https://mirrors.kodi.tv/addons/matrix/pv...oid-armv7/ and https://mirrors.kodi.tv/addons/matrix/pv...d-aarch64/ but there was not any working client.
I updated to KODI 19 on my X96max+ and it is connected to my VU+ Uno via Enigma2client.
KODI 18.9 was working fine before.....
Thank you for your help.
(2021-03-26, 21:40)vawaver Wrote: [ -> ]Hello,
That is the correct location and 7.4.2 is the latest version. But on android you should not need to download it. It should update from the binary addon repos as far as I’m aware.
Are you using vanilla Kodi? I.e. from the play store?
Thank you for your answer.
So I finally decided to uninstall KODI 19 + addons completely.
After reinstallation, all is working fine including Enigma2 addon.
Great!
