Full Version: DAVS is unsopported?
hi
After the upgrade ( from 18to v19) my kodi says WEbdavS is not supported protocol:
2021-02-27 21:45:59.718 T:11528    INFO <general>: VideoInfoScanner: Starting scan ..
2021-02-27 21:45:59.777 T:11528   ERROR <general>: CCurlFile::Exists - Failed: Unsupported protocol(1) for davs://USERNAMETongue[email protected]:443/video/
Does anyone has a solution?
(2021-02-27, 22:51)poli12 Wrote: [ -> ]hi
I'm having the exact same problem at the same time  Huh
At my first install, it has scrapped properly my library but now impossible to update it
Webdav(s) supposed to be the problem but not sure cause it worked for the first scan...
If you have any solution, let me knows please  Smile
So much issue on Matrix .....
