Right now when KODI is listing titles it ignores the articles when sorting the titles. That is working fine, however I now have some foreign movies with other non-English articles, for example in French: Le, La, Les and L'. Is there a way to add those to the article list?
Thanks...RDK
Karellen....Thanks. Seems to work, I added the following to the advancedsteeings.xml file, which for OSMC already existed but with the commented lines:
Quote: sudo cat /home/osmc/.kodi/userdata/advancedsettings.xml
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<recentlyaddeditems>0</recentlyaddeditems>
</videolibrary>
<advancedsettings>
<sorttokens>
<token>Le</token>
<token>Les</token>
<token>La</token>
<token separators="'">L</token>
</sorttokens>
</advancedsettings>
The one that does not seem to be working "correctly" is "Les" where it now places "Les Visiteurs Collection" at the top of the list
Thanks....RDK
Karellen....Forget it, I figured it out, an extra space after "Les" in the title. :-(
Hmmm, as usual I put my question at the end of the note and thus, you evidently missed it. Can you comment on
Quote:The one that does not seem to be working "correctly" is "Les" as it now places "Les Visiteurs Collection" at the top of the list??
Thanks...Rob
(2021-03-04, 10:14)rdk45 Wrote: [ -> ]Can you comment on
Your first line "
Forget it, I figured it out, an extra space after "Les" in the title" so I read that as solved.
What comment are you after?
No comment expected, issue solved. I answered my own question just after I posted the question.
The question referenced was at the end of my March 2 post....RDK
