2021-03-01, 22:55
I understand your not able to customise the home main menu items since Estuary is the default home screen and the user needs a skin to fall back onto in case another skin gets messed up.
I would like to suggest two feature requests for Estuary
1. Just like you can add/remove add-ons to your favorites, you can also add/remove add-ons to your home main menu as an item.
2. Be able to reorder items on the main menu. However addons items that were added to the main menu are under an "addons pin" home menu item. For example...
Movies
TV Shows
Music
Add-On Items
Weather
Radio
Add-Ons Pin
Favorites
In this example, all the addon items that you add to your main menu will be listed in alphabetical order between the Music item and the Weather item and you cannot reorder every specific addon item. You can even hide the "Addon items" item so no addons that you added to the main menu will appear in the main menu just like how you can hide the movies item and no movies item will appear in the main menu.
Movies
TV Shows
Music
Add-On Items
Weather
Radio
Add-Ons Pin
Favorites
