Hello!
I try to scrape via the Kodi Scraper (I have installed Kodi locally on my Mac), but all I can chose is this:
"Kodi: The Movie Database - 5.1.7"
But I have another Scraper installed in Kodi named "Videobuster".
How can I chose this one in tinyMediaManager?
Thank you for help!
where has the scraper been downloaded by Kodi? according to
https://kodi.wiki/?title=Userdata#addon_data this should be /Users/<your_user_name>/Library/Application Support/Kodi/addons (and this will be searched for according to the code)
(2021-03-02, 18:59)mlaggner Wrote: [ -> ]this should be /Users/<your_user_name>/Library/Application Support/Kodi/addons
Yes, there it is:
text:
addons:
total 0
drwxr-xr-x 5 carsten staff 160 1 Mär 21:23 .
drwxr-xr-x 9 carsten staff 288 5 Mär 09:45 ..
drwxr-xr-x 7 carsten staff 224 1 Mär 21:23 metadata.videobuster.de
drwxr-xr-x 2 carsten staff 64 1 Mär 21:20 packages
drwxr-xr-x 2 carsten staff 64 1 Mär 21:23 temp
whats the content of that videobuster folder?
Is this a new python based one?
Because we only support the old-style XML based scrapers...
I've found a possible issue there... When we search for addons in the Kodi user folder, we take ~/.kodi prior to ~/Application Support/Kodi (due to some sort of default in Linux). But the problem is, that ~/.kodi exists in macOS (but there is only a temp folder on my machine).
I suppose changing this should fix loading for you. Nevertheless - support of python scrapers cannot be done
(2021-03-05, 16:16)myron Wrote: [ -> ]Is this a new python based one?
It seems to be a xml scraper:
text:
metadata.videobuster.de:
total 72
drwxr-xr-x 7 carsten staff 224 1 Mär 21:23 .
drwxr-xr-x 6 carsten staff 192 5 Mär 09:48 ..
-rw-r--r-- 1 carsten staff 2080 1 Mär 21:23 addon.xml
-rw-r--r-- 1 carsten staff 1689 1 Mär 21:23 changelog.txt
-rw-r--r-- 1 carsten staff 12598 1 Mär 21:23 icon.png
drwxr-xr-x 3 carsten staff 96 1 Mär 21:23 resources
-rw-r--r-- 1 carsten staff 8363 1 Mär 21:23 videobuster.xml
(2021-03-05, 16:47)mlaggner Wrote: [ -> ]that ~/.kodi exists in macOS (but there is only a temp folder on my machine).
Yes, this folder is existing!
After changing it to another name it works! tinyMediaManager shows me the scraper.
I will look if it works.
Thank you for that fast solution!
