Does anyone know how to install dazn for kodi 19? It was in the kodi repo before, but I can’t find it on there since the update.
It will need to be updated to Python 3 to be compatible with Matrix.
I don't think the addon has a support thread here, so you may have to wait for it to be updated, or if the author has abandoned the addon then you may be out of luck.
I found
this GitHub repo which I think may be somewhere to see if you can confirm if any update is pending.
(2021-03-03, 14:57)DarrenHill Wrote: [ -> ]It will need to be updated to Python 3 to be compatible with Matrix.
I found this GitHub repo which I think may be somewhere to see if you can confirm if any update is pending.
Thanks. I'm comfortable working with python, but never created/worked on a repo before. If I was to update it myself, is it as simple as changing the code from Python 2.7 to Python 3?
(2021-03-03, 17:32)A600 Wrote: [ -> ]No need for that There already is a Matrix version:
This add-on does not work on matrix 19.1, are there any updates? ...
Since in Italy Dazn has the TV rights for Serie A football matches for the next 3 years .. it would be very useful.
(2021-06-24, 14:33)marcopt Wrote: [ -> ] (2021-03-03, 17:32)A600 Wrote: [ -> ]No need for that There already is a Matrix version:
Hi did you find a version that works in Matrix?
What do you mean it doesn't work? I have been using it for a while on Matrix 19.1, 19.2 and 19.3
How do I install the plugin from github? There are no instructions
Ok i downloaded the zip file but it gives python error on matrix 20.1
thats because it's incompatible, you will need to locate the developer and request they update the addon to use python 3.0.0+
currently its using 2.26.0
from the addon.xml file:
xml:
<import addon="xbmc.python" version="2.26.0"/>
Not working after entering login details
