Full Version: Find png from xml files ?
Hello, I would like to know where are stored all of the png files used in Estuary, for example, in the Estuary skin in the Custom_1109_TopBarOverlay.xml file, there is this line :
xml:
<texture>frame/osdfade.png</texture>
But I can't find the osdfade.png file
I just find out, they are in the media folder in .xbt files and you can extract the png files with this tool : https://kodi.wiki/view/TextureTool
(2021-03-04, 02:57)Karellen Wrote: [ -> ]Here... https://github.com/xbmc/xbmc/tree/master...edia/frame
Thanks for this link
Thread marked solved.
