I used to use the Guilloz (sp?) version of Estuary and customized my menus quite a bit. Having just installed KODI 19, I see that the base Estuary mod doesn't seem to allow even using playlists as menu items ('films', 'short films' etc.).
Question 1: Am I wrong about that ?
Question 2: Is there another version of Estuary that allows for even minimal customization (choosing a playlist for a menu heading so one can at least divide up the video library into sections).
Thanks a lot !
(2021-03-05, 21:46)filmcsb Wrote: [ -> ]I used to use the Guilloz (sp?) version of Estuary and customized my menus quite a bit. Having just installed KODI 19, I see that the base Estuary mod doesn't seem to allow even using playlists as menu items ('films', 'short films' etc.).
Thanks a lot !
I believe the Guilloz Estuary Mod 2 is unmaintained.
Kodinerds repo has a Estuary Mod 2 converted to Kodi 19 Matrix.
(2021-03-07, 19:43)markus40 Wrote: [ -> ] (2021-03-05, 21:46)filmcsb Wrote: [ -> ]I used to use the Guilloz (sp?) version of Estuary and customized my menus quite a bit. Having just installed KODI 19, I see that the base Estuary mod doesn't seem to allow even using playlists as menu items ('films', 'short films' etc.).
Thanks a lot !
Thanks Markus - great tip. I'll have a look.
(2021-03-08, 14:00)filmcsb Wrote: [ -> ] (2021-03-07, 19:43)markus40 Wrote: [ -> ] (2021-03-05, 21:46)filmcsb Wrote: [ -> ]I used to use the Guilloz (sp?) version of Estuary and customized my menus quite a bit. Having just installed KODI 19, I see that the base Estuary mod doesn't seem to allow even using playlists as menu items ('films', 'short films' etc.).
Thanks a lot !
Hrm. looks like that repo has been nuked from the planet. I'll keep looking around, though..
Would like to see the vanilla Estuary skin to allow for customising the main menu by adding add-ons to the main menu.
