Full Version: Change position of green dot
Hello bsoranio.
Many thanks for this great skin. I´m using it for couple of minutes and I like your skin. I'm running Amber on Kodi 19.
Iď like to ask you, is there any way how to change the position of green dot in pvr guide? Now the green dot is in the left side and up, and dot is behind the text.
What should I change if I want to move the green dot to ride side and down?
The green dot means that channel has catchup enabled (new feature of Matrix).
Sorry for my english, hope you understand.
https://imgur.com/a/vxoEulW
(2021-03-08, 14:45)Franky Doparoma Wrote: [ -> ]Hello bsoranio.
@Franky Doparoma, thank you for your feedback.  I had not noticed this, my PVR provider does not support catchup.  I will change the position to be to the left of the time (below the text).  Would that be all right with you? Please let me know.  Thanks.
Regards,
Bart
@bsoriano, thank you for answer, yes, it will be all right with that position. Thank you very much.
Regards,
Frank
(2021-03-08, 20:34)Franky Doparoma Wrote: [ -> ]@bsoriano, thank you for answer, yes, it will be all right with that position. Thank you very much.
Regards,
Frank
@Franky Doparoma , could you please try the latest from Git? I did not move the icon to the line with the start time, but I have improved its position and fixed some issues with it.  Please let me know if it looks all right to you now.  Thanks.
Regards,
Bart
@bsoriano,
thank you very much for this change, the green dot is vissible great. Laugh
Regards,
Frank.
https://imgur.com/a/kDvV7n3
(2021-03-12, 13:00)Franky Doparoma Wrote: [ -> ]@bsoriano,
Regards,
Frank.
@Franky Doparoma , thank you for confirming.
Regards,
Bart
