Full Version: Way to tell programmatically if channel load in from NPVR has finished...
I looked for a developer thread and couldnt see one...although im in the UK and you want to try getting an opticians appointment here...anyway, I am using NPVR as my PVR backend and have been writing a lot of automation in Python. What I am looking for in either Kodi or NPVR is some sort of trigger/flag/DB entry whatever that tells you the EPG load in from NPVR is complete. I could set a timer trigger based on how long the channel load usually takes, but this feels a bit half baked...if anyone can suggest a solution, that would be great...
Here is the link to your post in the NextPVR forum.  In the future please don't double post or I won't replay to either post.
https://forums.nextpvr.com/showthread.ph...#pid554221
Martin
