Full Version: Script newbie: calling scripts from main menu/ invoking applications
for simple Bluray playback, I wanted to invoke PowerDVD from XBMC main menu.
Unfortunately I found no how-to on achieving this, so I digged a bit into the XBMC skin and script interfaces.
Currently I'm using this approach (using xtv here):
<item>
<icon>icon-disc.png</icon>
<thumb>icon-disc-blur2.png</thumb>
<label>Bluray</label>
<onclick>xbmc.RunScript(Q:\scripts\powerdvd.py)</onclick>
</item>
For some reason, my script seems not to be invoked. Is there something that I need to pay attention to?
Second issue is how to minimize XBMC and invoke PowerDVD. Do you have a hint on how to do this? Does os.system() work from within XBMC?
Or, after all, are there better approaches for invoking such application from XBMC?
cheers,
Stephan
I recently found XBMC and am setting up a new HTPC with it. The question with Blu-Ray came up and I had the same idea as stephan: Adding a Blu-Ray option to the main menu and invoking PowerDVD from there. I'm using the MediaStream skin here.
If this is the wrong board for this please let me/us know.
maybe you can use the launcher plugin.
I use this to launch any piece of software on my htpc.
See you.
stephan Wrote:Hi,
<item>
</item>
cheers,
Stephan
If your script is in UserData (NOT the root of XBMC ), try U: instead of Q: . I use this on a Linux Box and onestly i can't remember if it would work on a windows Box, but trying it doesn't cost a thing, right?
ZIOLele
