Full Version: Nitpicking: Series status text alignment
Bart,
Really nitpicking here but just noticed that the text alignment for the series status (under the TV series name) is different than the text alignment for the movie set text (under the movie name) in the fanart view.
The series status text is aligned to the bottom of the screen, can you move that a bit upwards (like the text under a movie set name)?
(2021-03-12, 00:22)RyFeR Wrote: [ -> ]Bart,
@RyFeR , no worries! With the smallest of details the skin gets better.  I imagine you are speaking of the Netflix style of Fanart view.  Please confirm.  If so, yes, I will change the positioning so that it is consistent between media types.  Thanks.
Regards,
Bart
EDIT: @RyFeR , please try the latest from Git.  The positioning should now be consistent between tv shows and movie sets.  Thanks.
Hi Bart,
Correct alignment of the text under the movie name in fanart view:
Alignment to low (against the bottom of the screen) under the TV show name in fanart view:
And indeed this is in the Netflix style of the Fanart view.
Hope this makes it more clear, if you need more info please let me know
(2021-03-12, 15:47)RyFeR Wrote: [ -> ]Hi Bart,
Bart,
Just noticed you already updated the skin... Installed the latest version from GitHub and as expected the text under the TV show name is now properly aligned.
Thank you very much sir!
(2021-03-12, 16:39)RyFeR Wrote: [ -> ]
Bart,
@RyFeR , thanks for confirming.
Regards,
Bart
