Full Version: Harmony Hub Controller
Harmony Hub Controller let's you setup actions to run a Harmony activity and/or a sequence of remote commands. Running the addon gives you a menu of your actions, and you can also send an action name as an arg to have the script run a specific action.
It's available for Leia and Matrix from the Official Add-on repository.  Instructions for use are at:
https://kodi.wiki/view/Add-on:Harmony_Hub_Controller
Was able to setup and run the hub activities fine (macOS 10.15.7). After turning on debugging I can't seem to find the complete list of commands.
Seeing in the log:
2021-03-22 05:32:51.012 T:1256123   DEBUG <general>: [Harmony Hub Control] name 'unicode' is not defined
2021-03-22 05:32:51.012 T:1256123   DEBUG <general>: [Harmony Hub Control] error parsing logline
najujixeyu.kodi (paste)
Thanks for the great add-on!
Yea, I saw that a few days ago.  I have fixed it, I just need to submit the update.  Let me do that today. It generally takes a couple of days to get through the review process, then it should update automatically.
Quote:Please don't post log snippets to the forum. In the future, if you need to post any debug information, place the entire debug log into something like pastebin and then post a link to it. That said, I see what the issue is and have corrected it.  I'll try to get an updated version posted in the next couple of days.
And just as an FYI, I have asked the mods to merge this thread with the actual support thread so I can keep everything in one place. So don't be surprised when this moves.
I am sorry, I will keep that in mind. I just tried version 0.2.1 and get the same error.
(2021-04-10, 16:41)pierocol Wrote: [ -> ]
0.2.2 is the version that fixes that. If you're on Matrix, that version should be pushing out to the repo today. On Leia, we have to wait until the Matrix repo syncs before Leia can be updated, so it may be a couple more days.
(2021-04-11, 01:35)pkscout Wrote: [ -> ]
thanks a lot. I am on Matrix. I will test it and let you know.
(2021-04-11, 10:44)pierocol Wrote: [ -> ]
I just tried and I still get an error message. Here is the portion of the log file related to Harmony Hub Control. Thank you
(2021-04-11, 17:05)pierocol Wrote: [ -> ]
(2021-04-11, 01:35)pkscout Wrote: [ -> ]0.2.2 is the version that fixes that. If you're on Matrix, that version should be pushing out to the repo today. On Leia, we have to wait until the Matrix repo syncs before Leia can be updated, so it may be a couple more days.
Troubleshooting can only be done effectively if you post the complete debug log.
(2021-04-12, 00:22)pkscout Wrote: [ -> ]
(2021-04-11, 10:44)pierocol Wrote: [ -> ]thanks a lot. I am on Matrix. I will test it and let you know.
Sorry about that. I just tried again now in order to generate a "fresh" log, and much to my positive surprise it worked! I was able to start two of the "Activities" that I have configured on my Harmony Hub. I will setup also the other and test it further. I am very grateful. Thank you for your efforts (and for your patience with me)
(2021-04-12, 20:30)pierocol Wrote: [ -> ]
(2021-04-11, 17:05)pierocol Wrote: [ -> ]I just tried and I still get an error message. Here is the portion of the log file related to Harmony Hub Control. Thank you
It took me awhile, but I was able to track down the circumstances that caused your crash and duplicate them. Thus the fix.  Glad it worked.
