Full Version: Cannot sort by RT or MS column
If you click RT or MS column header to sort rows, it gives bunch of errors and you have to close the program. Then it won't start with this error:
java.lang.IllegalStateException: TableComparatorChooser can not sort objects "70", "53" using the provided Comparator
should be fixed in the next version
Working fine now. Thanks for the fix!
This change might have caused it but MS and RT columns no longer show "100" properly.
It's fixed. Thanks!
