Full Version: Remove menus from Music Library
Hello.
I will try to make my question as simple and clear as possible.
I would like Files menu to be shown in my Music Library, and delete everything else.
My question is:
How to do it?
Thank you for your help in advance.
pingvinszar2
P.S.:
If I posted my question to the wrong forum, please forgive me, and move it to the right one.
(2021-03-16, 17:10)pingvinszar Wrote: [ -> ]If I posted my question to the wrong forum, please forgive me, and move it to the right one.
You are not using the default Kodi skin Estuary. Which skin are you using?
(2021-03-16, 17:21)Klojum Wrote: [ -> ]
I use Confluence.
(2021-03-16, 17:22)pingvinszar Wrote: [ -> ]I use Confluence.
I can see that, partly. But I'm thinking it's a mod version looking at the font in the menu listing.
I just want to place this thread in the correct skin (sub) folder.
(2021-03-16, 17:27)Klojum Wrote: [ -> ]
It's the default one.
The font styles were added by myself.
The easiest way to do this is to just copy the files.xml node (and only that one) from the system nodes into the correct location in the userdata directory.  https://kodi.wiki/view/Music_nodes
This will give you only the files view in any skin although you are missing out on an awful lot of flexibility by not using the library.
Thread moved to Confluence skin section.
