Full Version: TRAKT Addin not working
i completely uninstalled Kodi, deleted all folders in prog files and appdata, reinstalled
the only other addin I use is Emby-Next-Gen.
windows 10 PC
Using Kodi Matrix for the past few weeks, was on Kodi 18 prior to that.  I found my Trakt history hasn't updated since October.  Noticed that after doing a fresh install of Kodi and shows I've watched over the past few months appeared as unwatched.
Log file is at https://paste.kodi.tv/isadagitoh
I have verified I can get into the trakt site without issue manually.
unsure if it is relevant, however i noticed in the addon settings, the username is blank,  I thought it used to have my trakt username in there.
I have authorised about 15 times over the past couple of weeks while troubleshooting and it always says successful.
(2021-03-17, 15:50)peakay Wrote: [ -> ]Log file is a
Next time, please restart Kodi immediately after enabling debugging. Things could be missed when the details start only halfway the log file. Thx.
You also may want to post in the official Trakt thread here: https://forum.kodi.tv/showthread.php?tid...pid3023920
Problems with Matrix are known and are being worked on. Check the last few pages there.
(2021-03-18, 02:08)jmh2002 Wrote: [ -> ]You also may want to post in the official Trakt thread here: https://forum.kodi.tv/showthread.php?tid...pid3023920
thanks for the info, i have copied to the TrakT Forum.
