Full Version: Feature request: Theme column
Since the ability to download theme songs for shows has been added it would be great to have the option for a column in the shows section showing if the show has or is missing a theme file.
Can you also consider adding votes (IMDb) & video bitrate columns for TV shows?
Hi
I will add the colums in TMM in near future
(2021-03-24, 21:04)wjanes Wrote: [ -> ]I will add the colums in TMM in near future
Noticed votes column for TV shows is added to the nightly. Thanks a lot!
One more request. Can you add "Movie set" to "field to edit" for bulk editor expert mode?
I'd like to bulk change movie set name following some other field values.
not possible, because movie set name is no string value but an other entity and the bulk editor is only able to create string values.
Thanks for adding the new columns!
