Hello,
Just re-installed my Raspberry again and installed Kodi. Next I always had the Amber skin.
Now installed the Amber skin, but I'm missing the 'Movies' from the 'homescreen'. It's a fresh install from Amber. Don't no what I am doing wrong.
I'm on Libreelec 9.2.6
(2021-03-27, 16:07)jasiccama Wrote: [ -> ]Hello,
jasiccama , are the other main menu items present? TV Shows, etc.? If you switch to Estuary skin, does it show a Movies menu item? And finally, and I apologize in advance for asking, do you have movies in your Kodi library? Amber will not show the menu item if you do not have movies in your library.
Regards,
Bart
(2021-03-27, 18:06)bsoriano Wrote: [ -> ] (2021-03-27, 16:07)jasiccama Wrote: [ -> ]Hello,
@jasiccama , are the other main menu items present? TV Shows, etc.? If you switch to Estuary skin, does it show a Movies menu item? And finally, and I apologize in advance for asking, do you have movies in your Kodi library? Amber will not show the menu item if you do not have movies in your library.
Regards,
Bart
My answer on your frist two question is yes
But your last remark is a good one. I didn't know that. I will link my movies and see if it does anything. Thanks.
