2021-03-27, 21:01
2021-03-27, 21:01
2021-03-27, 21:02
Previous Updates:
30/12/2020 - 0.19.0
[CODED] Initial Matrix Release
04/03/2021 - 0.19.1
[FIXED] Color overlay on TV posters removed
[FIXED] Artist Slideshow display
[FIXED] Add missing keyboard keys
21/03/2021 - 0.19.2
[FIXED] Color overlay on additional views
[FIXED] Settings dialog visibility and overlay
[FIXED] Allow seeking with arrow keys
[FIXED] Adjust layout for transparency issues
[FIXED] Adjust Skin Shortcuts window layout
[FIXED] PVR Info Dialog default focus
[ADDED] Global Search window
[ADDED] Allow custom background per main menu item
14/06/2021 - 0.19.3
[FIXED] Custom background option
[FIXED] Default icons
[FIXED] Use submenu as widget
[UPDATED] Language translations
https://github.com/bumpaneer/skin.unity/tree/Matrix
30/12/2020 - 0.19.0
04/03/2021 - 0.19.1
21/03/2021 - 0.19.2
14/06/2021 - 0.19.3
2021-03-28, 20:04
Installing version 0.19.2 may revert your main menu customizations to default.
To quickly restore the previous layout, you should be able to use the "Restore menu items" option on the Customize Main Menu window. Then choose "Import from compatible skin" followed by "Shared menu" to restore your previous items.
2021-08-19, 18:34
Is there a "Recently added shows" widget instead of episodes, available?
