2021-03-28, 11:48
This could be due to upgrading to Kodi Matrix, but I'm not sure.
Earlier, when I connected to a network drive (plugged into another PC), it connected instantly and I could start playing the files.
Now (since around the time I upgraded to Kodi Matrix) when I open the network drive and click on any root folder within, Kodi just freezes for upto 5 minutes.
During this time nothing works. After about 5 minutes, the folder opens and thereafter I can scroll the files as usual.
But if I exit that folder and try to open another root folder, the same issue occurs.
I also noticed that if i opened the drive and let t just sit there for 5 minutes, i could open the root folders without delay.
Is there a fix for this ? Thank you !!
