2021-03-31, 19:17
Hello, I am using Estuary on Kodi Matrix and I added the white icon studio addon but there is one that is not in the textures.xbt file so I would to know how to add one ?
(2021-03-31, 19:17)Bungee_G Wrote: [ -> ]Hello, I am using Estuary on Kodi Matrix and I added the white icon studio addon but there is one that is not in the textures.xbt file so I would to know how to add one ?Submit your additions here: https://github.com/XBMC-Addons/resource....dios.white
(2021-03-31, 19:24)Lunatixz Wrote: [ -> ](2021-03-31, 19:17)Bungee_G Wrote: [ -> ]Hello, I am using Estuary on Kodi Matrix and I added the white icon studio addon but there is one that is not in the textures.xbt file so I would to know how to add one ?Submit your additions here: https://github.com/XBMC-Addons/resource....dios.white
BTW no need to get involved with git, you can drag and drop your logos and create a commit through the web interface.
(2021-03-31, 19:30)Bungee_G Wrote: [ -> ]Short answer, Correct... You'll have to submit your changes and have them become official...(2021-03-31, 19:24)Lunatixz Wrote: [ -> ](2021-03-31, 19:17)Bungee_G Wrote: [ -> ]Hello, I am using Estuary on Kodi Matrix and I added the white icon studio addon but there is one that is not in the textures.xbt file so I would to know how to add one ?Submit your additions here: https://github.com/XBMC-Addons/resource....dios.white
Oh okay thanks so it is not possible to add it locally without doing what you said , is it ? Because I don't think the logo I have respect the image requirements :
https://github.com/XBMC-Addons/resource....-464534085
(2021-03-31, 19:40)Lunatixz Wrote: [ -> ]And what if I extract the Textures.xbt file then I add my png file then I compile the folder into a new Textures.xbt files ?(2021-03-31, 19:30)Bungee_G Wrote: [ -> ]Short answer, Correct... You'll have to submit your changes and have them become official...(2021-03-31, 19:24)Lunatixz Wrote: [ -> ]Submit your additions here: https://github.com/XBMC-Addons/resource....dios.white
Long answer, You can fork this project, add your own images and then you'll have to change all your skins, etc to use your new fork.
(2021-03-31, 19:51)Bungee_G Wrote: [ -> ]you can extract the Textures.xbt and just use the images from folder (delete Textures.xbt from folder)(2021-03-31, 19:40)Lunatixz Wrote: [ -> ]And what if I extract the Textures.xbt file then I add my png file then I compile the folder into a new Textures.xbt files ?(2021-03-31, 19:30)Bungee_G Wrote: [ -> ]Oh okay thanks so it is not possible to add it locally without doing what you said , is it ? Because I don't think the logo I have respect the image requirements :Short answer, Correct... You'll have to submit your changes and have them become official...
