2021-03-31, 19:43
Hello all,
I am trying to load a file all the time. The certificate of the domain is correct, it has been checked several times, but again and again I get this error. What can do there?
I have already tried to append
Am grateful for any help.
|verifypeer=false
after the URL. No success. It doesn't matter if I use http://
or https://
.Code:
Error Type: <class 'urllib.error.URLError'>
Error Contents: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1123)>
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 1350, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1424, in connect
self.sock = self._context.wrap_socket(self.sock,
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/ssl.py", line 1040, in _create
self.do_handshake()
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1123)
During handling of the above exception, another exception occurred:
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/addons/script.cuetv.install/main.py", line 14, in <module>
script.get_packages()
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/addons/script.cuetv.install/resources/lib/script.py", line 68, in get_packages
response = urllib.request.urlopen(url)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 531, in open
response = meth(req, response)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 640, in http_response
response = self.parent.error(
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 563, in error
result = self._call_chain(*args)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 502, in _call_chain
result = func(*args)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 755, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 525, in open
response = self._open(req, data)
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 542, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 1393, in https_open
return self.do_open(http.client.HTTPSConnection, req,
File "/data/user/0/org.xbmc.kodk/cache/apk/assets/python3.8/lib/python3.8/urllib/request.py", line 1353, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1123)>
python:url = 'http://SEITE.cc/tv/data.zip|verifypeer=false'
