2021-04-02, 02:04
2021-04-02, 03:55
There is a button for remote to the right of FF (Hover over the small thumbnail.). The stop button is on the remote.
Hope that helps.
Cheers,
LongMan
Hope that helps.
Cheers,
LongMan
2021-04-07, 01:19
(2021-04-02, 03:55)LongMan Wrote: [ -> ]There is a button for remote to the right of FF (Hover over the small thumbnail.). The stop button is on the remote.
Hope that helps.
Cheers,
LongMan
LongMan,
On mine, there is a grey box beside the fast forward. The icon for the remote only shows up when you hover over the grey box. I had always ignored it since it didn't look like anything.
Thank you.
Brian
2022-08-28, 09:44
Hope that helps.
Cheers,
LongMan
Ow man...
I was searching for the same thing and mine showed a thumbnail of the show that is playing. Never would have thought it acts like a on screen remote! They should give it a clear remote icon imo!
thnx
