Full Version: [WINDOWS] WMA (and WMA in WMV) digital audio pass-through to SP/DIF
I have a receiver that according to specifications can decode WMA audio. Now I have some WMV movies in which I assume the audio is in WMA format. Is it possible with XBMC to send such a stream to my receiver just as with DD and DTS?
With Zoomplayer I used to live encode the WMA stream to a DD 5.1 stream so my receiver would play the 5.1 sound of a WMV file. Is something like this maybe possible in XBMC?
Currently XBMC doesn't play sound at all through my receiver for WMV files. DTS, PCM and DD work fine.
currently, no, it's on the todo after atlantis
Ok, I will eagerly anticipating that one for the future then Wink
One more question:
Do you plan to add digital output of WMA or reencoding wma to DD or both?
mdvries Wrote:Do you plan to add digital output of WMA or reencoding wma to DD or both?
I do not know about digital output of WMA but transcoding WMA to AC3 will probably make it into XBMC sooner or later, but it first depends on two things, see:
http://forum.xbmc.org/showthread.php?tid=27455
and
http://forum.xbmc.org/showthread.php?tid=34130
Feel free to post your comments in those threads Nod
Is there any general restrictions or problems with a passthrough of WMA? It would seem much easier (as a first step) to just passthrough the WMA audio to digital out?
I do not know, but in any case please submit a new feature request for it to our tracking system http://trac.xbmc.org
phunqe Wrote:Is there any general restrictions or problems with a passthrough of WMA? It would seem much easier (as a first step) to just passthrough the WMA audio to digital out?
I can only speak for myself and there're two things:
1) missing equipment for testing (I don't need it because stereo is fine for me)
2) missing knowledge to code it without testing
Patches are welcome Nod
