2021-04-10, 19:30
Pages: 1 2
2021-04-11, 04:43
well i think this is something build in kodi but you can create radiobuttons for multiple selections
2021-04-11, 06:21
(2021-04-11, 04:43)moshep15 Wrote: [ -> ]well i think this is something build in kodi but you can create radiobuttons for multiple selections
Thanks for your answer... But a radiobutton is only on/off so it is not possible to choose multiples settings
2021-04-11, 14:02
(2021-04-11, 06:21)Bungee_G Wrote: [ -> ](2021-04-11, 04:43)moshep15 Wrote: [ -> ]well i think this is something build in kodi but you can create radiobuttons for multiple selections
You can use a button control with different onclick conditions and corresponding secondary labels. That way you can toggle through a list of setting states. You won't get a settings list where a few settings can be active at the same time. Those settings options are exclusively available for built-in Kodi settings, I'm afraid.
The only way to get something really close to that would be to build a list of radiobutton controls that emulate a Kodi settings list.
2021-04-11, 14:27
2021-04-11, 18:51
(2021-04-11, 14:27)Hitcher Wrote: [ -> ]Use script.toolbox.
https://github.com/phil65/script.toolbox
Thanks for this but when I try to install script.toolbox I get an error, is it compatible with Kodi Matrix ?
2021-04-11, 19:06
Did you install through Kodi?
2021-04-11, 19:06
2021-04-11, 19:28
(2021-04-11, 19:06)Hitcher Wrote: [ -> ]https://github.com/xbmc/repo-scripts/tre...pt.toolboxNow it works, thanks !
I would like to try this in Estuary, so if I want to add a multiple selection setting in the skinsettings.xml file
What should I add ? This ? :
xml:<control type="button"> </control>
If yes what have I to put inside this control button ? For example, if I have 5 options named Test1, Test2, Test3, Test4 and Test5
2021-04-11, 20:02
https://forum.kodi.tv/showthread.php?tid=207618
<onclick>SetProperty(Dialog.1.Label,Test)</onclick>
<onclick>SetProperty(Dialog.1.BuiltIn,builtin1)</onclick>
<onclick>SetProperty(Dialog.2.Label,Test 2)</onclick>
<onclick>SetProperty(Dialog.2.BuiltIn,builtin2)</onclick>
<onclick>SetProperty(Dialog.3.Label,Test 3)</onclick>
<onclick>SetProperty(Dialog.3.BuiltIn,builtin3)</onclick>
<onclick>SetProperty(Dialog.4.Label,Test 4)</onclick>
<onclick>SetProperty(Dialog.4.BuiltIn,builtin4)</onclick>
<onclick>RunScript(script.toolbox,info=selectdialog,header=This is a custom dialog)</onclick>
</control>
2021-04-11, 20:06
you can force dialogselect or better a custom dialog force open and use custom button grouplist
https://github.com/marduklev/skin.swan-a...Select.xml
- here i use it to focus a panel with id 40, in diaog select to chosse just one item based on a custom property which is set before.
or using
Skin.SelectBool(header, label1|setting1, label2|setting2)
https://kodi.wiki/view/List_of_built-in_functions
if youre just want select one of a few skinsettings.
will require localized strings.
so you should usea grouplist with defined toggle buttonsxml:
<onload condition="!String.IsEmpty(Window(home).Property(ShortcutPlaylistContent))">SetFocus(40)</onload>
or using
2021-04-11, 20:06
(2021-04-11, 20:02)Hitcher Wrote: [ -> ]https://forum.kodi.tv/showthread.php?tid=207618I tried this (I didn't define Test, Test 2, Test 3 and Test 4), but when I click on one of the Test, the window closes :
</control>
xml:<control type="button" id="920">
<label>$LOCALIZE[40374]</label>
<include>DefaultSettingButton</include>
<onclick>RunScript(script.toolbox,info=selectdialog,header=Choose a Test)</onclick>
</control>
2021-04-11, 20:11
Thanks for your answer @mardukL , when I use Skin.SelectBool I can only select one option while I want to select the ones I want (all of them, none, 1 or two,...)
2021-04-11, 20:12
So for example, I have these two image control (clearlogos) :
How do I make a setting that permits me to choose if I want to display the clearlogo named Test 1 or Test 2 or both or none ?
I think I forgot to add in these two control :
Or I don’t know...
xml:<control type="image" name="Test 1">
<top>100</top>
<width>284</width>
<height>110</height>
<left>155</left>
<aspectratio align="center" aligny="center">keep</aspectratio>
<texture>$VAR[LibraryClearLogoVar]</texture>
<visible>Control.IsVisible(55)</visible>
<visible>Container.Content(episodes)</visible>
</control>
xml:<control type="image" name="Test 2">
<top>100</top>
<width>284</width>
<left>155</left>
<visible>Control.IsVisible(51)</visible>
</control>
andxml:<visible>Skin.HasSetting(Test1)</visible>
Andxml:<visible>Skin.HasSetting(Test2)</visible>
andxml:<include condition="[Skin.HasSetting(Test1)]">Test 1</include>
xml:<include condition="[Skin.HasSetting(Test2)]">Test 2</include>
Or I don’t know...
2021-04-11, 22:21
Can you help me please ? I would like to try with these two control
Pages: 1 2
