Full Version: 3D H-SBS playback on active 3D TV has doubled (quadruple sides)
Hi. I am using Kodi Matrix 19.0.0.210 build for QNAPClub HD Station. I updated it from KODI v19 Alpha few days ago.
Until previous version, I could watch my 3D H-SBS correctly, but now the display keeps "doubling" the frame.
Trying to explain better: My QNAP NAS is playing through last generation HDMI cable to my Hisense active 3D TV.
Previously, when I started a 3D H-SBS video, KODI asked me to select the 3D mode, after chosing that, it doubled the user interface vertically with single left and right side separately, then I could activate 3D mode on my TV so it showed the correct unique full screen frame (mixed layers).
After upgrading to new version, doing the same actions, KODI double the user interface as before, but every side of screen keeps to show the double sides instead of single, so they become 4 (2 after activating 3D on TV).
The only way to make it work is to DISABLE 3D on KODI and enable it only on my TV. The movie is showing now correctly, but the user interface becomes orizzontally stretched. Most of all, subtitles are totally unreadable because half of them start on the right side of display and the other half continue on the left side, all stretched.
I checked every "expert" options and also tried to follow the guides but I cannot figure it out. Sorry if I didn't explain well, I can provide pictures of the results and, of course, logs if needed.
Thanks in advance for any help.
