Full Version: Enigma2 - MySQL library requested but MySQL support is not compiled in.
Hi all,
I have a problem, I use Zgemma H9 Combo boxes, and I started using the Kodi 18.9.
The program works fine until I connect to the database.
My advancedsettings.xml:
  <videodatabase>
    <type>mysql</type>
    <name>username</name>
    <host>192.168.178.254</host>
    <port>3307</port>
    <user>user</user>
    <pass>pass</pass>
  </videodatabase>
  <musicdatabase>
     <type>mysql</type>
    <port>3307</port>
     <user>user</user>
     <pass>pass</pass>
  </musicdatabase>
This file works well on other devices. (Android, Windows etc.)
Debug log in Enigma2 (Zgemma H9 Combo box):
2021-04-19 09:55:37.825 T:2895115168  NOTICE: Running database version Addons27
2021-04-19 09:55:37.826 T:2895115168  NOTICE: Running database version ViewModes6
2021-04-19 09:55:37.828 T:2895115168  NOTICE: Running database version Textures13
2021-04-19 09:55:37.828 T:2895115168   ERROR: MySQL library requested but MySQL support is not compiled in. Falling back to sqlite3.
2021-04-19 09:55:37.830 T:2895115168   FATAL: SqliteDatabase: can't open 192.168.178.254/dbname.db
2021-04-19 09:55:37.832 T:2895115168   ERROR: Process error processing job
What is my chance for access to my SQL Dbase? (I use MariaDB 10 in Synology NAS)
Thank you!
SF
If you are running Kodi on an Enigma2 device you will to raise the issue on the forum for your E2 image.
(2021-04-19, 10:12)sasfioka Wrote: [ -> ]I use Zgemma H9 Combo boxes, and I started using the Kodi 18.9.
The company of the Zgemma H9 simply didn't bother to add the MySQL functionality in their own build of Kodi.
You'll have to ask them to reconsider and add it.
