Full Version: Virtual File System causing error when playing ISO files
Hoping someone can help me out. I recently upgraded to Matrix and noticed that my ISO files would not play. The screen would turn black for a second and immediately return to the menu. I found the following error in the log file linked to the issue:
2021-04-21 10:11:00.906 T:31048    INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-04-21 10:11:00.906 T:31048    INFO <general>: Trying to open: samplerate: 44100, channelMask: 12, encoding: 4
2021-04-21 10:11:00.916 T:31048    INFO <general>: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 56720 m_frames: 1772 m_frameSize: 8 channels: 2
2021-04-21 10:11:00.927 T:3198    ERROR <general>: GetDirectory - Error getting videodb://movies/titles/82?xsp=%7b%22order%22%3a%7b%22direction%22%3a%22ascending%22%2c%22ignorefolders%22%3a0%2c%22method%22%3a%22sorttitle%22%7d%2c%22rules%22%3a%7b%22and%22%3a%5b%7b%22field%22%3a%22path%22%2c%22operator%22%3a%22contains%22%2c%22value%22%3a%5b%22movies%22%5d%7d%5d%7d%2c%22type%22%3a%22movies%22%7d
2021-04-21 10:11:00.930 T:30993   ERROR <general>: CGUIMediaWindow::GetDirectory(videodb://movies/titles/82?xsp=%7b%22order%22%3a%7b%22direction%22%3a%22ascending%22%2c%22ignorefolders%22%3a0%2c%22method%22%3a%22sorttitle%22%7d%2c%22rules%22%3a%7b%22and%22%3a%5b%7b%22field%22%3a%22path%22%2c%22operator%22%3a%22contains%22%2c%22value%22%3a%5b%22movies%22%5d%7d%5d%7d%2c%22type%22%3a%22movies%22%7d) failed
It appears to be some problem with the VFS add-on that is required by Super Sub Titles. When I remove Super Subtitles and VFS, the ISO files play fine. Any thoughts on how I can keep Super Sub and VFS and still play ISO files? This all worked fine under Leiah
Thanks in advance!
