2021-04-23, 16:04
Hello there,
I use my google drive to stream directly to Kodi on my android box (without pc or any other machine on). With Movies and TV show, theres no problem, I´ve exported strm files and added to my library, and I find all the infos and arts. The problem is with my music concerts, because most of them there are no info available over the internet, so I´ve edited some NFO files to them. The problem is that they are not used if I stream directly from the gdrive. If I place all my files in my HD, they work great, but using the cloud, don´t.
Is there a way to use google drive and get the infos from NFO files?
Thank you all, and sorry for my bad english
- Cheers
- Cheers
