Full Version: FLAC file with embedded cue sheet only showing one track
I have many albums I have ripped, each to a single flac file. I have embedded cue sheets in all of them, together with separate cue sheets - all in separate folders. V18.9 managed to find all songs (not sure if it was from the embedded cue sheet or separate .cue file). Upgrading to 19 and all these albums only show 1 track. I have converted one album to separate files and these are seen by the library system
Any ideas how I get the system to read the embedded cue sheet in the flac file without converting to separate files?
Yes there is a regression in v19.0 which impacts cuesheets, see long discussion https://forum.kodi.tv/showthread.php?tid=360791 which gives a work around.
It is fixed in v19.1 which will probably be released soon, or you could install the Matix nightly build
