Full Version: Added icons in Timer / Recording sections -- Recording list icons missing
Hello,
I am still using DVBlink PVR as a (fallback) solution. I noticed TV channel icons are now added in the Timer / Timer Rules / Recordings sections. Nice!
Timer sections show the channel icons fine, but if you select a recording list in Recordings, icons in the recordings list seem missing and a black vertical 'ribbon' with missing icons picture is shown across the list.
Is it possible to have TV channel icons be shown in recordings list instead of the black ribbon of missing icons ?  Alternatively, a screenshot of the recording itself could be shown (which is shown on the right hand side with the series description already).
Thanks for reading,
Atreyu
Removed info according to findings.
(2021-05-05, 14:30)Atreyu Wrote: [ -> ]
After some investigation i suspect it's caused by a PVR Windows change in Kodi v19(.1).
Weird thing is, that not all OS'es or PVR addons suffer from this, but also not limited to TVMosiac (since DVBViewer also has this issue).
Hope someone involved in these changes will pick up on this. Visual example of the issue:
(2021-05-17, 09:56)Atreyu Wrote: [ -> ]fixed by https://github.com/xbmc/xbmc/pull/19746
Yup, I noticed this had been fixed yesterday.
However, one of my very old recordings has never had a channel logo because it didn't exist when the recording was made and noticed that in this instance, the old portrait icon with the black background is still applied.
Update: Scrub this. Just noticed I'd also recorded 2 programmes last week with no channel icon in place and they are showing on the recording screen without any default icon, so not quite sure why I'm getting differences. Bit of a mystery..... Wink
