2021-05-02, 16:11
2021-05-02, 16:27
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
2021-05-11, 22:36
2021-05-14, 18:40
(2021-05-11, 22:36)ueffchen Wrote: [ -> ]Here is the debug zemegucude.kodi (paste)If someone can give me a hint, I can also experiment by myself. Currently I have no clue however
does that help to find the problem
