Hi I have an Intel NUC Kit NUC8i3BEH windows 10 Kodi matrix, video card default settings. But I can't get the colors in kodi right, when I use the netflix addon I have a lot of artifacts in the picture. Is there a guide to the best video card settings. thanks
This is what used to work for me on my NUC's with the old Intel Graphics Control Panel:
Kodi - set to Limited
Driver Quantization Range - Full
YCbCr - Off
Video Input Range - Application Setting
Noise Reduction - Application
Turn off all the film mode and color enhancement options
TV black level - Low
But, I can't make sense out of the new Intel Graphics Command Center which replaces the old one. Good luck with that.
Also, you need some calibration files to setup your brightness & contrast levels properly ->
https://www.avsforum.com/threads/avs-hd-...on.948496/
All you really need are the Black Clipping and White Clipping files...
