Full Version: Migrated service add-on is seg faulting kodi 19.0
I'm migrating an add-on from python 2 to python 3 and when trying the add-on on Kodi 19.0 (Ubuntu 20.04), Kodi is seg faulting on the second or subsequent loading of kodi
I've started with a blank .kodi folder so this is the only additional add-on and it is repeatable so confident it is something I've done.
The crashlog says the seg fault is in #0  0x00007f3efc121816 in _PyObject_GetMethod () from /usr/lib/x86_64-linux-gnu/libpython3.8.so.1.0
That doesn't mean much to me. I had debug logging switched on and note the debug information in the top left corner doesn't update for a few seconds before it crashes.
I would appreciate some help/pointers in how to debug what could be causing it. Thanks
Crashlog
I've added log commands around blocks of code and through a process of elimination I've narrowed it down to a requests.post command:
custom_headers = { 'user-agent': xbmc.getUserAgent(), 'Content-Type': 'application/json' }
log.info("Snapshot 2")
r = requests.post(url=register_endpoint, data=json.dumps(data_to_submit), headers=custom_headers, timeout=_request_timeout)
log.info("Snapshot 2a")
Steps to reproduce:
1) Start Kodi with add-on uninstalled
2) Install add-on using "Install from zip file"
3) In the log file it prints "Snapshot 2" and "Snapshot 2a" (plus later logs) - i.e. the requests.post command works correctly
4) Exit and restart Kodi
5) Add-on is started and last log line is "Snapshot 2" then Kodi crashes, implying the requests.post command is causing the crash
