2021-05-11, 02:39
Pages: 1 2
2021-05-11, 08:48
(2021-05-11, 02:39)Brakiss Wrote: [ -> ]Wont load, just hangs and I get crash log.
https://paste.kodi.tv/umeyacilez.kodi
try install graphic drivers, follow this instructions
https://tutorialforlinux.com/2021/03/04/...tallation/
2021-05-11, 17:46
(2021-05-11, 08:48)alfton Wrote: [ -> ]Have tried that, says they are already installed.(2021-05-11, 02:39)Brakiss Wrote: [ -> ]Wont load, just hangs and I get crash log.
2021-05-12, 07:55
@yol any ideas? there was also a report of a similar/same issue with flatpak
2021-05-13, 19:44
2021-05-14, 10:57
I was able to upgrade from Ubuntu 20.10 to 21.04, but experience many addon oddities in addons because of python problems. Maybe this is related?
2021-05-14, 18:23
(2021-05-14, 10:57)Nosepull Wrote: [ -> ]I was able to upgrade from Ubuntu 20.10 to 21.04, but experience many addon oddities in addons because of python problems. Maybe this is related?no I fresh installed
2021-05-14, 22:48
I haven't seen this on my machine yet. Difficult to say anything without libwayland-client++ debug symbols. Maybe you could install those? And please activate debug logging in Kodi.
@wsnipex do you have further details about the flatpak report?
2021-05-15, 07:43
(2021-05-14, 22:48)yol Wrote: [ -> ]I haven't seen this on my machine yet. Difficult to say anything without libwayland-client++ debug symbols. Maybe you could install those? And please activate debug logging in Kodi.
https://github.com/flathub/tv.kodi.Kodi/issues/112
2021-05-15, 08:08
2021-05-15, 08:11
In the meantime, my best guess is that the CWindowDecorator stuff in the backtrace is a red herring and that "WARNING <general>: wayland-client log message: wl_drm@11: error 0: authenticate failed" is closer to the actual issue
2021-05-15, 16:05
Hi there. I saw a GitHub issue I opened has been mentioned in this thread.
Let me add some more details in case they help.
1. I'm running the latest flatpak version (see here)
2. This is the stdout log when running with WAYLAND_DEBUG=1 (in order to do this, I first run "flatpak run --command=bash tv.kodi.Kodi" and then, once inside the flatpak "container", this other command: "WAYLAND_DEBUG=1 kodi")
3. This is the kodi.log file
2021-05-15, 16:20
@greenfoo Thanks. It looks like VA-API is trying to authenticate a render node and failing. Can you run WAYLAND_DEBUG=1 vainfo and maybe ls -l /dev/dri/by-path on the host and the latter also in the container? And just to confirm, you can run Kodi OK directly on your OS without the flatpak?
2021-05-15, 16:21
Also both of you please tell me which compositors you use and maybe try it with another one, preferably weston :-)
2021-05-15, 20:22
Thanks yol.
Remember I'm running the flatpak version, thus in order to run "vainfo" I had to copy the "vainfo" binary from the "host" to the flatpak "container" first:
If I re-run with WAYLAND_DEBUG=1, like this...
I'm using Sway but I tried with Gnome and obtained the same result, but only with the flatpak version (that's why I originally opened the issue only in the github repository that manages Kodi's flatpak port). If I run the Kodi version provided by my distro package manager, it works without problems (both vainfo and kodi):
Finally, this is how "/dev/dri/by-path" looks like inside and outside the flatpak "container":
Knowing almost nothing about how flatpaks are built, could this be an issue in the way Kodi was packaged as a flatpak? Maybe something extra in the flatpak manifest needs to be done to allow access to these devices? (I tried to run "vainfo" on other flatpaks and it also failed, but maybe those other flatpak apps don't need vaapi to run and they never bothered to add that capability to the manifest?)
bash:
$ cp /usr/bin/vainfo .var/app/tv.kodi.Kodi/data/temp
$ flatpak run --command=bash tv.kodi.Kodi
[📦 tv.kodi.Kodi ~]$ .var/app/tv.kodi.Kodi/data/temp/vainfo
wl_drm@6: error 0: authenticate failed
VA error: wayland: Wayland roundtrip error: Protocol error (errno 71)
libva info: VA-API version 1.8.0
libva error: vaGetDriverNameByIndex() failed with invalid VADisplay, driver_name = (null)
vaInitialize failed with error code 3 (invalid VADisplay),exit
...then I get the output shown here.bash:
[📦 tv.kodi.Kodi ~]$ WAYLAND_DEBUG=1 .var/app/tv.kodi.Kodi/data/temp/vainfo
bash:
$ vainfo
vainfo: VA-API version: 1.11 (libva 2.11.1)
vainfo: Driver version: Mesa Gallium driver 21.1.0 for AMD Radeon Vega 8 Graphics (RAVEN, DRM 3.40.0, 5.12.3-arch1-1, LLVM 11.1.0)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
bash:
[📦 tv.kodi.Kodi ~]$ ls /dev/dri/by-path/ -l
total 0
lrwxrwxrwx 1 nfsnobody nfsnobody 8 May 15 19:31 pci-0000:05:00.0-card -> ../card0
lrwxrwxrwx 1 nfsnobody nfsnobody 13 May 15 16:11 pci-0000:05:00.0-render -> ../renderD128
bash:
total 0
lrwxrwxrwx 1 root root 8 May 15 19:31 pci-0000:05:00.0-card -> ../card0
lrwxrwxrwx 1 root root 13 May 15 16:11 pci-0000:05:00.0-render -> ../renderD128
Pages: 1 2
