Hi there,
i just tried to upgrade Kodi from 19.0 to 19.1 with this:
sudo apt update
sudo apt upgrade --with-new-pkgs
but nothing happens...
I don't think 19.1 was packaged so there is nothing for apt to pull down.
Are you sure?
In the package-list of Kodi stable there is an entry:
kodi 2:19.1+git20210509.0555-85e05228b4-0~hirsute Wolfgang Schupp (2021-05-09)
I am not sure/I haven't run Debian/Ubuntu is years. If you're seeing an entry in a repo for a new version, and if you have apt configured to hit that repo, I don't understand why it wouldn't happily pull down the newer version. As an aside, I don't recall needing/using the --with-new-pkgs
switches before.
(2021-05-12, 16:46)graysky Wrote: [ -> ]... I don't understand why it wouldn't happily pull down the newer version.
Yes, me too...
Is it available now?
If not, please get us the output of sudo apt update && apt-cache policy kodi
No, its still not available here.
The wanted output is following:
Thanks for your answer!
Well,
so do you think there is something wrong on my side?
Is there somebody, who can confirm, that the repo is ok?
(2021-05-12, 14:01)contadino Wrote: [ -> ]Are you sure?
Yes, i know...
But that does not help me, because here on my side it seems, the repo is empty?!
And yes, the installed version 19.0 is the groovy-version. I installed it in february - at that time there was no hirsute.
(2021-05-18, 15:50)contadino Wrote: [ -> ] (2021-05-12, 14:01)contadino Wrote: [ -> ]Are you sure?
Yes, i know...
As I see it, the TeamXBMC-repo for ubuntu currently contains only the main binary and one pvr addon in a hirsute version. Everything else is missing. I updated to this version, but you necessarily end up with a mixture of versions, as all the other addons necessary for a proper Kodi are missing.
Moreover, there seem to be lots of Python related problems with this Kodi version. I ended up going back to Kodi 19.0 as packaged by Ubuntu to get a reasonably working system.
Uhuh. What Nosepull said :-)
I initially installed 19.1 from the PPA, but the three things I require to integrate with existing media network stuffs (pvr.hts, pvr.mythtv and vfs.sftp) were (/are) not yet packaged for Hirsute.
So I settled for 19.0 from Ubuntu. For about 24 hours, then a couple of hours ago I built git master (shows as 20.0-ALPHA1 (19.90.101)). Easy build, although took a while to execute, and all seems well so far...
Cheers,
Mattt.
right, this is a bug in our jenkins build scripts.
I'm manually pushing addons to the ppa atm
Thanks wsnipex!
There are a lot of the addons now in the hirsute -repo.
But sorry - here on my side i still can not upgrade neither kodi nor the addons...
How can that be possible?!
idk, broken system?
full output of: apt policy kodi
and: apt full-upgrade
