Full Version: pvr.mediaportal.tvserver
Hello,
yesterday i make the Update vom Kodi 19.0 to 19.1. All was Fine and i can view TV and hear Broadcast. Today after Starting Kodi i can´t view TV, can´t hear Broadcast or view Recordings!
After Viewing the Applications-Log I see following error (soory, German System):
____________________________________
Name der fehlerhaften Anwendung: kodi.exe, Version: 19.1.0.0, Zeitstempel: 0x6096c388
Name des fehlerhaften Moduls: pvr.mediaportal.tvserver.dll, Version: 0.0.0.0, Zeitstempel: 0x609c380d
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00000000000087da
ID des fehlerhaften Prozesses: 0x1520
Startzeit der fehlerhaften Anwendung: 0x01d747dcf4154f5a
Pfad der fehlerhaften Anwendung: C:\Program Files\Kodi\kodi.exe
Pfad des fehlerhaften Moduls: C:\Users\einka\AppData\Roaming\Kodi\addons\pvr.mediaportal.tvserver\pvr.mediaportal.tvserver.dll
Berichtskennung: 5698a576-95cb-41e5-b14e-98807ec4647c
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
In the Kodi.log I get follwing Error after switiing to a TV Chanel:
2021-05-13 12:56:38.161 T:4876     INFO <general>: Loading skin file: MyPVRGuide.xml, load type: KEEP_IN_MEMORY
2021-05-13 12:56:40.444 T:4876     INFO <general>: Loading skin file: DialogPVRInfo.xml, load type: LOAD_EVERY_TIME
2021-05-13 12:56:42.200 T:4876     INFO <general>: VideoPlayer::OpenFile: pvr://channels/radio/Alle%20Kan%c3%a4le/pvr.mediaportal.tvserver_391.pvr
2021-05-13 12:56:42.202 T:5932     INFO <general>: Creating InputStream
2021-05-13 12:56:42.202 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: Open Live stream for channel uid=391
2021-05-13 12:56:42.318 T:4876  WARNING <general>: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 107, because topmost modal dialog closing animation is running
2021-05-13 12:56:44.142 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: Channel timeshift buffer: D:\Timeshift\live3-0.ts.tsbuffer
2021-05-13 12:56:44.242 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: Creating a new TsReader...
2021-05-13 12:56:44.242 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: TsReader open 'D:\Timeshift\live3-0.ts.tsbuffer'
2021-05-13 12:56:44.242 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: Cannot access 'D:\Timeshift\live3-0.ts.tsbuffer' directly. Assuming multiseat mode. Need to translate to UNC filename.
2021-05-13 12:56:44.243 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: Translate path D:\Timeshift\live3-0.ts.tsbuffer -> D:\Timeshift\live3-0.ts.tsbuffer
2021-05-13 12:56:44.243 T:5932    ERROR <general>: AddOnLog: pvr.mediaportal.tvserver: Cannot find or access file: D:\Timeshift\live3-0.ts.tsbuffer. Check share access rights.
2021-05-13 12:56:44.243 T:5932    ERROR <general>: AddOnLog: pvr.mediaportal.tvserver: Cannot open timeshift buffer D:\Timeshift\live3-0.ts.tsbuffer
2021-05-13 12:56:44.243 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: TsReader: closing file
2021-05-13 12:56:47.295 T:5932     INFO <general>: AddOnLog: pvr.mediaportal.tvserver: CloseLiveStream: True
2021-05-13 12:56:47.295 T:5932    ERROR <general>: CVideoPlayer::OpenInputStream - error opening [pvr://channels/radio/Alle%20Kan%c3%a4le/pvr.mediaportal.tvserver_391.pvr]
2021-05-13 12:56:47.295 T:5932     INFO <general>: CVideoPlayer::OnExit()
2021-05-13 12:56:47.379 T:4876     INFO <general>: CVideoPlayer::CloseFile()
2021-05-13 12:56:47.379 T:4876     INFO <general>: VideoPlayer: waiting for threads to exit
2021-05-13 12:56:47.379 T:4876     INFO <general>: VideoPlayer: finished waiting
2021-05-13 12:56:53.461 T:4876  WARNING <general>: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 107, because topmost modal dialog closing animation is running
Why can´t access the Timeshift Folder?
There was an Update yesterday of the Plugin at 23:11!!!  It seems that is the Problem;-)
Sincerly, Karsten.
Hi, try to see which version of the Mediaportal PVR Client Add-on you have installed on your system, if you have updates set automatically you should have version 8.1.1.0, this version does not work for me too, I solved it by disabling automatic updates and installing the previous version of the Add-on .. 8.1.0.0
Marco.
(2021-05-13, 14:41)marcopt Wrote: [ -> ]Hi, try to see which version of the Mediaportal PVR Client Add-on you have installed on your system, if you have updates set automatically you should have version 8.1.1.0, this version does not work for me too, I solved it by disabling automatic updates and installing the previous version of the Add-on .. 8.1.0.0
Marco.
Thank you Marco. Yes, yesterday the Plugin was Updated to Version 8.1.1.0. Rollback to previous Version 8.1.0.0 solved the Problem. Disabled the automatic Update for this Plugin.
Karsten.
(2021-05-13, 13:25)Karsten0506 Wrote: [ -> ]2021-05-13 12:56:44.243 T:5932    ERROR <general>: AddOnLog: pvr.mediaportal.tvserver: Cannot find or access file: D:\Timeshift\live3-0.ts.tsbuffer. Check share access rights.
Hello Karsten,
It looks like the MP-TV-server has lost the access rights to your TV-Buffer!
By October 2021, I had also connected KODI to the MP-TV-Server Vers: 1.26.000.0  Nothing worked with Kodi 19 (Matrix) at first.
I bought the DVBViewer TV server and it is much better, faster and more stable. Disadvantage: price (2 * 19.00 Euro). Update from Kodi 19.0 -> 19.1 no problems.
Sincerly, ClausMM
DVBViewer
@alwinus can you take a look? It appears there is an issue with the latest version.
Can someone post a full debug log of the issue please so we can try to fix this?
@phunkyfish I wonder if this should be -1 not 0 https://github.com/kodi-pvr/pvr.mediapor...7803301R38
Following through to MultiByteToWideChar(...) the definition https://docs.microsoft.com/en-us/windows...towidechar says
Quote:Size, in bytes, of the string indicated by the lpMultiByteStr parameter. Alternatively, this parameter can be set to -1 if the string is null-terminated. Note that, if cbMultiByte is 0, the function fails.
Martin
I can confirm that v8.1.1 under Kodi 19.1 (Win x64) is not working anymore.
How can i go back to the previous version?
Download and install the zip from github did not work for me.
(2021-05-13, 20:13)emveepee Wrote: [ -> ]@phunkyfish I wonder if this should be -1 not 0 https://github.com/kodi-pvr/pvr.mediapor...7803301R38
Martin
Let's try it. Creating test builds.
(2021-05-13, 20:46)Keksebacker Wrote: [ -> ]I can confirm that v8.1.1 under Kodi 19.1 (Win x64) is not working anymore.
You can't use a zip from github because this is a binary addon and must be compiled.
Please try these testbuilds that has a likely fix: https://jenkins.kodi.tv/blue/organizatio.../artifacts
(2021-05-13, 18:38)phunkyfish Wrote: [ -> ]@alwinus can you take a look? It appears there is an issue with the latest version.
https://paste.kodi.tv/ufuroqucad.kodi
(2021-05-13, 21:35)phunkyfish Wrote: [ -> ]Please try these testbuilds that has a likely fix: https://jenkins.kodi.tv/blue/organizatio.../artifacts
THX!
Works perfectly.
(2021-05-13, 21:51)Keksebacker Wrote: [ -> ]
THX!
Works perfectly.
Great will release it shortly. @alwinus no need to look. Thanks @emveepee for the fix!
Ok, I've kicked off the release. It should arrive in auto-updates from tomorrow.
(2021-05-13, 23:01)phunkyfish Wrote: [ -> ]Ok, I've kicked off the release. It should arrive in auto-updates from tomorrow.
Thank you, Version 8.1.2 works fine
