2021-05-14, 00:27
I just installed a fresh KODI 19 (LibreELEC 9.95.2) to my Pi4. I recently acquired a Synology DS916+ and so I moved my entire library over there. I set it up to connect via NFS.
Within KODI I have no Movies or TV selections. At first I assumed that was because I had nothing in my library yet (could still be the case). Inside the Videos tab I added source and I began adding each of the sources for my movies and TV shows. I could navigate to the folders fine, set them up as Movies/TV etc. but then nothing populates. It doesn't add anything to the library.
Within Videos I can navigate to the individual movies and play them just fine, but I'm navigating through a file structure.
Before the Synology I had all content on my PC and connected via SMB, which is why I'm assuming it's an NFS issue. I've never used NFS before, but I was instructed to connect KODI to the Synology in this way.
FWIW It's also set up as a KODI server with MariaDB10.
Here is my log file
Here is my log file
