Full Version: Custom shadertoys.
I just found the Shadertoys plugin and I really like it. I am writing my own but I have to run them by pasting my shader into one of the presets in ~/.kodi/addons/visualization.shadertoy/resources because I don't know where the filenames of the presets are stored. If they are not hard coded in the binary the first place. So is there a more elegant way to do things? Like a custom.frag.glsl I can add to the list to play around with?
Ohaï !
Just came here to say I'm really interested in this too, I managed to modify presets.json and to copy my shader but it seems I can't make audio+buffer work, I also don't really know how to do that as I'm a shadertoy Newbie Smile
Here is the shader I wan't to add to Kodi :
https://www.shadertoy.com/view/lsSfDD
Here is why Spectrogram would be cool to have in Kodi ( ^◡^)っ
https://en.wikipedia.org/wiki/Spectrogram
I also can post logs or else if anyone want to give a hand Smile
There are actually two different shadertoy add-ons, one for screensaver and one for music visualization. The music visualization add-on has some direct options to use custom presets via JSON or or a single custom .glsl file. The screensaver shadertoy also lets you use your own shader under settings and at least on Windows opens a file explorer to let you pick a file.
If you play around with that please post your experiences.
