2021-05-15, 15:51
I need some help after re-installing a Raspberry Pi 3B+ with Librelec 9.2.6 and Kodi 18.9.
The add-on Yelo (shycoderX - 10.03) has been installed with all required dependencies and starts without errors.
However, once a channel is selected, the actual streaming does not start. The loading icon appears, it turns, than stops, turns again for a short while and than the same screen is displayed.
I have the same issue with the Netflix add-on.
Inputstream adaptive and RTMP input are installed and acitivated.
Thanks in avance for your support.
Regards,
Geert
Regards,
Geert
